Discord: OneDrive folder issues
Discord: tetra326: I used the util to uninstall onedrive. However my folders are still in ./OneDrive/Documents and /Pictures. I am wanting to move them to a different harddrive but get this error
Can’t move the folder because there is a folder in the same location that can’t be redirected.
Access is denied.
Downloads moved just fine. Any ideas?
Discord: tetra326: Nevermind I fixed this by running the uninstall-onedrive tool again (cause I think it errored the first time), changing the permissions of the OneDrive folder to be changed by my user, then deleting the folder in explorer.
Restart
since the Desktop, Documents, and Pictures folders no longer existed, I could not move them to the new folders through explorer. you need to change it in the registry
