WinUtil Redesigns
WinUtil — 10 Alternate UI Designs
Same program, same real content.
How the current UI works (from the supplied screenshots): five top tabs, dark grey-blue theme, dense checkbox columns on Tweaks, app cards in a 3-wide grid on Install, action buttons stacked in side panels, and a status line pinned to the bottom. Its strengths: everything is visible at once and regulars are fast. Its costs: first-timers get no guidance, nothing explains a tweak before you tick it, and Updates/Creator already use cards and a wizard — so the program is quietly three different design languages at once.
At a glance — which one is for whom
# Design Big idea Best for Main trade-off
1 Fluent Sidebar Windows 11 Settings-style left navigation + switches Most users — feels native Less on screen at once
2 Guided Setup Wizard One decision per screen, in a safe order First-timers, family PCs Slower for regulars
3 Dashboard Home Status tiles + preset cards first, details second Repeat “new PC day” use Needs a real home screen built
4 Search-First / Run Queue Type what you want, queue it, run it all Power users, keyboard Browsing/discovery is weaker
5 App Store Grid Install becomes a visual store with a selection tray Choosing apps visually Tweaks/Config need a second style
6 Master–Detail Explorer Tree → list → plain-English explanation pane Cautious users, learning Takes the most screen width
7 Black & Red Pro Console Dense console, live log always visible Experts, SEAN’s house style Intimidating to beginners
8 Light & Large (Accessible) Big type, big switches, one column, light theme Older eyes, high-DPI, touch Long scrolling lists
9 Preset Matrix A table showing exactly what each preset includes Comparing Minimal/Standard/Advanced Only shines for Tweaks/presets
10 Recipe Builder Build, save, export and re-run a named setup Anyone who sets up many PCs Most new machinery to build
My pick if only one ships: #1 Fluent Sidebar as the shell, with #3’s preset cards on its home page and #6’s explanation pane for Tweaks. #10 is the standout feature hiding in a design — it turns WinUtil from “run it once” into “my saved setup, on every PC.”
Based on: Chris Titus Tech WinUtil ( GitHub - ChrisTitusTech/winutil: Chris Titus Tech's Windows Utility - Install Programs, Tweaks, Fixes, and Updates · GitHub ) and the five tab screenshots supplied 2026-10-25 — Install, Tweaks, Config, Updates, Win11 Creator. Mockups are original redesigns using WinUtil’s real labels and content; no upstream artwork copied.
