Discord: battery percentage wont show after apply some tweak
Discord: jesthazio: is there any way to do , except reinstall windows ?
Discord: reverieviee: Following up on your message here Discord
Let me get on my PC and look around. I’ll try to find a fix for ya
Discord: jesthazio: because i want to sold this second laptop to my friend
Discord: reverieviee: Can you open Device Manager, and under batteries take a screenshot of what’s shown there?
Discord: jesthazio: oke one sec
Discord: jesthazio: yes i remember i apply like standar or performance tweak on preset in CTT
Discord: reverieviee: Right-click Microsoft AC Adapter, click Uninstall device, and restart the computer. Don’t worry, Windows will reinstall it and hopefully fix the issue
Discord: jesthazio: okie one sec
Discord: jesthazio: i have no idea what to do after got this issue because i am really new on windows
Discord: reverieviee: yep
Discord: jesthazio: the battery section is showing again
Discord: reverieviee: can you click that button in device manager
Discord: reverieviee: sweet
Discord: reverieviee: Yep its back to Power & battery, we’re making progress
Discord: reverieviee: alright next test
Discord: reverieviee: open file explorer, then open task manager and under the processes tab you should see it there
Discord: jesthazio: omg
Discord: reverieviee: https://klipy.com/gifs/bocchi-bocchi-the-rock-212
Discord: jesthazio: but do you have any idea why that happen
Discord: jesthazio: i am using atlas os
