Discord: Epic Games / Easy Anti-Cheat "Untrusted System File" (amdlhk64.dll) after running Standard preset
Discord: alexmini: ### Version of WinUtil
26.07.17
What part of WinUtil are you having issues with?
Tweaks Tab
Provide a clear and concise description of the issue.
Description
After running WinUtil (Tweaks tab, “Standard” preset) on a friend’s laptop, Epic Games titles using Easy Anti-Cheat stopped launching. EAC now shows:
Easy Anti-Cheat
Untrusted system file
\?\GLOBALROOT\Device\HarddiskVolume3\Windows\System32\amdlhk64.dll
This started right after the WinUtil run.
Environment
  • Laptop: ASUS
  • CPU: AMD Ryzen (4th gen)
  • GPU: Nvidia RTX 2060
  • Storage: NVMe SSD + HDD
  • OS: Windows 11
  • WinUtil preset used: Standard
Steps to reproduce
  1. Run WinUtil (irm https://christitus.com/win | iex)
  2. Go to Tweaks tab, select the “Standard” preset, apply
  3. Reboot
  4. Launch any Epic Games title that uses Easy Anti-Cheat
Expected behavior
Game launches normally through Easy Anti-Cheat.
Actual behavior
Easy Anti-Cheat blocks the launch with “Untrusted system file” pointing to amdlhk64.dll.
Question
Has anyone else seen EAC/anti-cheat “untrusted file” errors correlate with running the Standard preset?
List the tweaks you applied before the issue occurred.
Paste the full error output (if available) or Screenshot or Video.
Discord: reverieviee: Hey I’ll look over this in just a bit. Thanks for reporting
Discord: reverieviee: <@304296381479256064> I took a look, left a comment on GitHub. Thanks for reporting!
Discord: alexmini: <@1471554971081113836> One thing I forgot to mention: during the run, the console said the tweaks were finished, but there was still a window open (looked like the disk cleanup, i don’t know for sure) that seemed stuck near the end. Since the console already said everything was done, I force-closed that window with the X button instead of waiting or cancelling it properly. Not sure if that’s related to the issue, just wanted to mention it in case it helps.
