Discord: Lenovo LOQ display brightness scaling broken after running CTT WinUtil & enabling Ultimate Performan
Discord: noxiousxdddd: System: Lenovo LOQ (Intel i5-12450HX + RTX 3050, Windows 11)
Issue: Screen brightness curve drops abruptly dark below 70%. In Hybrid mode, lower percentages goes to nearly pitch black.
Context:
I ran CTT WinUtil power/debloat tweaks and manually unhidden/enabled the Windows Ultimate Performance power scheme (which I later realized is designed for desktop PCs, not laptops). This seems to have stripped Lenovo’s native ACPI power rules and modified display registry hives (FeatureTestControl), breaking the PWM backlight voltage mapping for the panel.
Tried so far:
-Clean reinstalled official Lenovo OEM Intel VGA drivers.
-Set FeatureTestControl to ffff in Registry (Control\Class{4d36e968…}\0000).
-Executed powercfg -restoredefaultschemes to remove custom power plans and restarted Display Enhancement Service.
Looking for advice on restoring Lenovo OEM ACPI power tables or PWM duty cycle mapping without having to do a full OS reinstall.
Discord: mydrift: In control panel > power options u should be able to choose a power plan, can u check what that is set to rn and set it to balanced for testing?
Discord: noxiousxdddd: Power plan is already set to balanced and i restored it as well
Discord: noxiousxdddd: When i clicked the ultimate performance plan in the tool, suddenly the brightness dropped.
Discord: noxiousxdddd: Then i realised this is not for laptops.
Discord: noxiousxdddd: <@679006161554505729> Reinstalled windows, but the issue is not solved i guess, what other things I can do?
Discord: mydrift: well if u reinstalled windows it is not really an issue that winutil or the os caused. can u check ur monitor settings?
Discord: noxiousxdddd: Like what?
Discord: mydrift: there should be physical buttons on the monitor somewhere. with settings that the monitor itself manages
Discord: noxiousxdddd: No i have a laptop
Discord: noxiousxdddd: No external monitors
Discord: mydrift: oh sorry, did u run windows updates?
Discord: noxiousxdddd: Yes i did
Discord: mydrift: and install proper drivers manually maybe from manifacturer?
Discord: noxiousxdddd: Not tried but I’ll try
Discord: mydrift: hard to say. the display itself might be broken
Discord: noxiousxdddd: Can BIOS reseat help?
Discord: mydrift: I don’t think so
Discord: mydrift: I mean if u have not configured anything to important it should not really cause issues
Discord: noxiousxdddd: Don’t know what caused it
