Discord: Setup has failed to validate the product key despite fixes
Discord: .blastorix: Is anyone still having issues with Win 11 Creator? Been trying to repeatedly use it and it still has the "Setup has failed to validate the product key” issue despite fixes being made.
Discord: reverieviee: The refactoring isn’t in place yet, so you’re still using the old Win11 Creator which can cause that error. <@227623126488449035> is PR 4862 good to be merged?
Yes I’ll merge today
Discord: .blastorix: Thank goodness! I thought I was doing something wrong… :sob:
Discord: reverieviee: Let me know if you find any other issues! Or if you have any feedback.
Discord: .blastorix: Well, now it says USB Access is denied, and it doesn’t seem like it’s applying any debloating at all…
Discord: .blastorix: It seems like it’s still not fully working.
Discord: reverieviee: Be more specific, where did you get that error?
Discord: reverieviee: <@874645752322883584> I’ve managed to fix the USB Access is denied error locally, debloating/tweaks have been confirmed to work in multiple machines so I’d need more context.
