Discord: Updating to 26H2
Discord: donkeyness: I paid for Chris’s WINONESHOT and made a clean Iso, then installed it and I am very happy with how much faster everything is with no bloat etc, If I upgrade to 26H2 will Microslop place their Telemetry etc back in? Or redo by downlaoding 26H2 ahe running it through WINONESHOT and a clean install?
If you upgrade your existing installation to 26H2 using Windows Update, then you should expect, as usual, that Windows will retain most of your existing applications, files and settings. But that doesn’t guarantee that every change you’ve made using WINONESHOT will survive, because feature updates replace or modify Windows components. Consequently, some settings, registry modifications, disabled services and scheduled tasks may get reset, reconfigured or even rendered ineffective. A Windows feature update could also install new components and telemetry mechanisms that your existing debloating never addressed. The bottom line, in my opinion, is that one shouldn’t assume a debloated configuration will remain intact.
It seems to me, if I were in your position, there are two approaches to upgrading to 26H2.
  1. Download the latest Windows ISO with the new 26H2 changes already applied by Microsoft, run it through WINONESHOT, then perform a clean installation. This, I think, would be a more reliable approach if your priority is to maintain a deliberately stripped down Windows installation. By processing the new ISO through WINONESHOT, you can apply the tool’s modifications to the new Windows installation media before installing it.
Or—
  1. Allow Windows to install the 26H2 update over your existing setup. Then, afterwards, use Chris’s Windows Utility to clean it up.
Either way, grab a complete disk image using a bootable backup utility first. At least that way you can get right back to where you were before making any changes if you need to.
Also, before doing anything, just check that WINONESHOT now fully supports the 26H2 build. I would bet that it does, it’s maintained very quickly.
Exactly the way I would do it. Strip the source before installation with WINONESHOT. I think Chris and his contributors saw some of the hurdles coming with preview releases in update.
Discord: donkeyness: Thanks very much. probably download 26h2 and clean install, after all can’t trust microslop.
