Edit Discord Webhook look
I have next suggestion, so it looks a bit better in DIscord:
  • Name: nickname (Forum)
  • Avatar: url from forum
Because static image + Forum: username feels kinda not that interactive on other side :slight_smile:
Like this?
Kind of… Just noticed that my reference broke. I would move tag (Forum) to nickname
Improved sync today no longer dupes Discord to Discourse inside of discord
Eeeeeeeeeeeeehm, what? ._0
What
Super easy, barely an inconvenience
where is all the settings and css and all that. it that on git or is it all on the server?
Its a community plugin. https://github.com/christitustech/community
word of warning… this is ruby and other code. Editing this is not a simple task. Most PRs will be shutdown unless very targeted because discourse is a pain in the ass to customize.
ok, i forked that all ready lol. ill have a look at it. if i can help ill help.
I guess, context is here. Just switch username to “username (Forum)” and add avatar_url to JSON with parsing avatar URL from forum, cause idk how to get avatar from Discourse
I made a pull request to update the design of the general message sent from the forum. Not sure if it is the right syntax, though, since this is just based on how the other code was written. (Never used that language before.) https://github.com/ChrisTitusTech/community/pull/1
TITUS, I GUESS YOU MESSED UP XD
But yeah, @FallenGME , PR should be good, the only thing under question is variable, if it works, so does PR
u can approve anyones pr. thats just a gh feature.
I know, but most of his projects are open just for comment :slight_smile:
The design request from this Thread has been implemented, and will be available after the next rebuild. If you would like to Contribute yourself you can do so here: GitHub - ChrisTitusTech/community: Custom Discourse plugin - Twitch Subs, Discord Sync, YT Members, Github Sponsors, and Christitus.com Themed · GitHub
