I inst winutil, then used it. But after I closed it I found no way to re-start the pgm again. Any info?
The utility is referred to as WinUtil but the actual executable is called WinOneShot.exe
You can either do a search for WinOneShot.exe to locate it, or go find it at the location below…
C:\Users\********\AppData\Local\WinOneShot\WinOneShot.exe
note: - Replace ******** with your Windows username.
Once you find it, I suggest you right-click it once then click “Send to” then “Desktop(create shortcut)” for future use.
