I blindly used WinUtil, and now my Windows is corrupted: I can’t update it or install .NET Framework 3.5
hey, what’s the error messages you get? what tweaks have you run? did you try to undo the tweaks? more info needed
Similar issue here, cannot get it to install at all. Through PS it gets stuck on Enabling feature, through a popup or the component menu it gets stuck on searching for the files. Seems like this is not unheard of. Currently trying to to Config > .NET framework (version 2,3,4) - Enable, will advise of any success.
Discord: fishythegoober: ^ my reply
Discord: fishythegoober: Logs and command line, this is really frustrating.
Discord: fishythegoober: Yeah, my Windows is gone now. Tried to restart and it’s stuck on updating.
Sounds like me when I first started using Linux. You get it figured out?
