Installed, used, closed. How to restart?
I’ve replied to your previous question about this as follows…
The utility is referred to as WinUtil but the actual executable is called WinOneShot.exe
You can either do a search for WinOneShot.exe to locate it, or go find it at the location below…
C:\Users\********\AppData\Local\WinOneShot\WinOneShot.exe
note: - Replace ******** with your Windows username.
Once you find it, I suggest you right-click it once then click “Send to” then “Desktop(create shortcut)” for future use.
