Telemetry error running standard optimizations
I received the following error:
Error changing registry entry ‘HKEY_CURRENT_USER\Software\Microsoft\Siuf\Rules\PeriodInNanoSeconds’: The type of the value object did not match the specified RegistryValueKind or the object could not be properly converted.
Exception type: System.ArgumentException
Stack trace: at Microsoft.Win32.RegistryKey.SetValue(String name, Object value, RegistryValueKind valueKind)
at WinOneShot.RegistryManager.ChangeRegistryKey(String keyPath, String valueName, Object valueData, String valueType, Action`1 log) in C:\Users\Subscribe\Downloads\WinOneShot-Signing\v0.7.5\repository\RegistryManager.cs:line 62
That error is a type mismatch, not a permissions problem. The PeriodInNanoSeconds value under that HKCU key is normally a 64-bit QWORD, so the optimizer is likely trying to write it as DWORD or string. Set it as a QWORD, or skip that one telemetry tweak if the tool hardcodes the wrong type; the stack trace is worth reporting.
